2001 mazda B2300 starter wont disengage
Ramcharger90
1,708
N/A na
306, Bcam,
So we put a used motor in a 01 B2300 with the 2.3 the starter is getting stuck engaged when the engine starts.
8,374
2.3l DOHC Duratec was in the 2001 B2300
Did you uses the ring gear(flywheel/flexplate) from the old engine or the "new" used engine
Was there a spacer on the flywheel/flexplate?
And did the Block Plate get put back in?
Its the thin metal plate/spacer between engine and bellhousing, its used align starter motor and ring gear
Ramcharger90
1,708
N/A na
306, Bcam,
Yes to most it didnt have any so I used copper washers its much better now.
8,374
Good stuff
Ramcharger90
1,708
N/A na
306, Bcam,
It didnt have a block plate. It had a rubber spacer for the starter
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
😜 Wait what?
pjtoledo
3,020
Toledo Ohio
Fords
3.0 2.3
2.3 Duratecs don't use a block plate. the starter bolts go straight into the block.
there is a rubber seal between the starter nose and bell housing.
"needs verification alert" I think there are different starters for manual vs auto. the tooth counts are different.
