2003 fx4 level 2 project
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Did you do a full parasitic draw test?
North Idaho 5.oh
554
Idaho
Ford ranger
At the risk of sounding like a moron.... how do you do a parasitic draw test?
Pull each fuse with a bolt meter on the battery till you find the problem?
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Sorta. First test your battery and make sure its not the problem and that it's fully charged.
Open the doors but set the latches closed so the interior light doesn't come on. Disconnect the negative battery cable and hook up your volt meter on the highest DC amp setting from the negative battery terminal to the negative battery cable. You will see the amp draw on the meter. Pull fuses one by one and watch the meter, when the amp draw drops you have found the right fuse. Look to see what circuit that fuse controls and you have narrowed down your problem to something on that circuit.
*you can NOT hit the brake pedal or turn anything on while your doing this or you will blow up your volt meter.
*there will always be some draw, this is from the computers keep alive memory and power door lock reciever so pulling some fuses may cause a tiny drop, ignore those.
This video does a decent job explaining it.
waxclan
1995 Ranger XLT suffering a parasitic voltage loss for the last couple years so I put my meter between neg terminal and clamp and got 260 mA. Pulling fuses one at a time I found the GEM fuse killed the loss. Following the video
I took the chance and clipped the identified wire and now all is good - no voltage loss over the last 3 days plus dome light goes out with no time delay. While I was there I clipped the radio lighting wire to stop it dimming with the headlights on.
North Idaho 5.oh
554
Idaho
Ford ranger
Boy do I feel like a complete moron, but I did find the issue.
The corrosion behind the gage cluster was so bad that something (not sure exactly what) was killing the battery. Replaced the back of the cluster and all is well!
North Idaho 5.oh
554
Idaho
Ford ranger
Pulled the truck into the shop where I work and now the fun begins again.
Gonna be doing ball joints, tie rods, wheel bearings, etc....
Rear brakes are all bad and corroded so I’ll be doing rear shoes, hardware and cables too!
North Idaho 5.oh
554
Idaho
Ford ranger
More fun stuff.
I put in some “new to me” head lights and I like the way it turned out.
They are cheap china brand but they make the truck look a little more stealth lol
MaicoDoug
Ham Radio Operator
55
Texas
Ranger FX4 LVL2
2 inches in the back, not enough in the front
32x11.5x15
Watch out with those style of headlights, they leak and will fog up and corrode the reflective coating. I had a set when I purchased my 2007 yellow sub fx4L2. You can however add some sealant to the edges where the front & rear halves met. Good luck. I'm doing a front end rebuild also.
