2003 Ranger 5 speed manual transfer case swap?
00t444e
217
Southern OH
Ranger ext cab
I have an 03 Ranger 4x4 4.0 Extended cab 5 speed that I want to swap to a manual shift transfer case. From what I have read I need a BW 1354 manual shift transfer case, lever, linkage and driveshaft from a 90-97 model Ranger or from an 02 FX4 or 03 FX4 level 2, and I will need to fab a bracket for the linkage to bolt to since my transmission doesn't have the holes for the bolts (already confirmed). Can the transfer case come from an auto or manual Ranger or are the input shafts different, also did the 4 cyl models use the 1354 as well or does it have to be out of a V6?
8,372
For a 2003 Ranger yes, you will need the BW1354m, m is for manual, e was for` electric, they are often listed that way
Yes, manual and automatic used same setup, and engine size didn't matter
In 1998 all Ranger 4x4 transfer case's front drive shaft was changed to propeller joint
Manual transfer case was dropped in 1998 as an option, except for the Level IIs for a few years, as you mentioned
So yes, 1997 and earlier years would be what's available, and you will need the front drive shaft with it, probably the rear as well
You can just find the tail shaft housing with the Bosses(bolt holes) for shift linkage, most of these earlier years had them just the 1998 and up didn't
And its just 8 bolts to swap it out
Looks like this with the holes: https://i.ebayimg.com/images/g/YrEAAOSwNnRYhmPL/s-l500.jpg
Manual shift linkage and boots are hard to find, try to get a complete unit with all the parts
rubydist
865
Denver
Ford Ranger FX4
iirc, the manual t-case in the 02-03 Level II only was in manual trans trucks; the auto trans trucks had electric shift t-case, so the manual ones of that generation are pretty rare.
There is a company that makes a manual shift conversion kit that bolts onto the electric shift t-case. Its expensive but is less like looking for a needle in a haystack.
00t444e
217
Southern OH
Ranger ext cab
You mean this? https://behemothdrivetrain.com/products/borg-warner-electric-to-manual-shift-conversion-kit
Way overpriced, I can easily get a manual shift transfer case and all the parts for half that.
pjtoledo
2,992
Toledo Ohio
Fords
3.0 2.3
where?
1350 or 1354?
lowspeedpursuit
151
DE
B2300
I'm also curious. Are you just really lucky with junkyards where you live? I would love a shifter that's not cobbled together--not to mention a spare case--but we barely have 4x4 Rangers for parts around here, much less with manual-shift.
00t444e
217
Southern OH
Ranger ext cab
Yes I have a Ford junkyard nearby, transfer cases are $200-300, and maybe another $100 for the shift linkage and everything else.
pjtoledo
2,992
Toledo Ohio
Fords
3.0 2.3
now you definitely have my attention. does that yard actually have a manual shift linkage available?
I'm up in Toledo, retired, and like to take long drives just for something to do.
plus I could stop at Jegs on the way there. :icon_thumby:
lowspeedpursuit
151
DE
B2300
Likewise. I would happily pay $100 for a proper linkage and the dual-manual floor plate, plus whatever for shipping. Or, I usually end up in Ohio for work anyway once a year or so.
00t444e
217
Southern OH
Ranger ext cab
OK I found a mid 90s Ranger with the 5 speed and manual shift transfer case at the local junkyard, he agreed to $240 for the transfer case, shift lever, linkage, shifter boot, trim piece and the front driveshaft, I put down a deposit on it and he will have it all pulled in a couple days. Doing some reading on here it seems like I may need front driveshaft from an Explorer instead, is that true? I picked up an Explorer 8.8 from him for my Jeep project today, he has a few Explorers I could get a driveshaft from as well.
8,372
No, you need the front drive shaft that matches the transfer case, so mid-1990's drive shaft
In 1998 Ranger transfer cases got a new front connection, a propeller joint, and used the new Dana 35 SLA front axle
But I think the Dana 35 SLA u-joint should be the same as 1990-1997 Dana 28/35 TTB
