2003 Ranger suspension idea
Karbuster
Washington
2003 Mostly....
4.0L V6 (for now)
Curb? What curb, I felt a speedbump
I was talking to my mechanic friend the other day about doing a suspension lift on my ranger and he said just to get the shocks out of an F 150 has anyone here ever done that and how well does it work compared to aftermarket suspension kits? Also if I do that should I get a small body lift like 2 inches?
posted from Nexus 5
Karbuster
Washington
2003 Mostly....
4.0L V6 (for now)
After doing a better job seeking information I have come across articles that say the front drive shaft wears out in about 20,000 miles after you lift the truck, what should I do about that?
posted from Nexus 5
Black99Snake
colorado springs, co
1999
You cant use springs from an f150 unless your using the leafs for the rear. But the front has no springs it uses torsion bars to lift/lower the front. Only way to lift the front is a suspension lift kit or a solid axle swap. Or a body lift. If you crank the torsion bar all the way up you can clear 33s with minor rubbage on the sway bar. I had aftermarket wheels that were for a jeep cherokee that were 10in wide with 12.5in wide 33in tall with no rubbing. It will ride a lil stiff but it will still flex like crazy
Sent from my SM-G900P using Tapatalk
Karbuster
Washington
2003 Mostly....
4.0L V6 (for now)
sorry i never replied, gonna take this to heart for the next ranger, this one is going to be buttoned up with a couple more items and then left alone
