mr_woodster
- Jul 17, 2008
- 0
- Age
- 41
- Ford
Hey there, Thanks for the great forum. I've been a long time lurker and I've soaked up a ton of great knowledge on these forums.
Lately I've been exploring the Idea of converting my 2007 3.0 auto Sport to 4x4.
Yes, i've done a search
From what I've been able to dig up, Seems the Front end differential setup is pretty straight forward (needing a bracked welded to the frame).
My question in regards to the Front differential is:
It needs to be the same gear ratio as the rear correct? (in my case 4.10)
Is any 98+ front differential a worthy canidate or are there changes in the later model diffs?
I believe i have the 5R44E trans (being a 3.0 auto-5speed) and reading through some other swaps, the Output shaft is going to be needing to be swapped with a 4x4 shaft+ tail housing.
This is where there doesnt seem to be alot of information. Does the 5R55E 4x4 shaft swap into the 5R44EE ? What is the best shaft for (or which one to stay away from? ) my 07' trans?
Also Transfer cases, Is it pretty much anyone goes (the difference being manual or automatic locking) ? I see alot of transfer cases available, but not alot front Differentials.
I guess I'm looking for any tips in regards to the above questions, or advice in general.
Also, who here has the latest model 4x4 conversion? (hoping not to be the newest /first one )
thanks!
PS: this isn't my first project , i would say I have a pretty good grasp on custom projects/skills required.
thanks!
