Jazzer
- Mar 16, 2018
- 458
- Indianapolis
- Ranger
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 2WD
Looked in search, found nothing really.
This morning I replaced the thermostat after getting code 0128 I believe it was, insufficient coolant temp. After replacement, I got good cranking but no start. A test light grounded to battery and probe in coil showed no spark while cranking.
I had pulled the positive terminal from the battery before changing out the thermostat. It's possible I may have brushed it against a brake line but I don't remember any sparking.
I pulled the PCM relay (#54) and probed the slots in its receiver, and found 12V in one slot. I installed the blower relay in its place, but no joy.
I can't find wiring schematics online for this engine, so I thought I'd ask you fellas what I should check next?
Thanks for any and all replies!
-Jazzer
-Jazzer
