2009 Mazda B2300 steering shaft grease boot
mark2009B2300
78729
Mazda B2300
This part has been discontinued by Ford and Mazda. I think I can repair the by sewing where it split with nylon thread.
What do you think?
franklin2
1,769
Virginia
What size is the boot roughly on both ends? Will a universal shock boot work? About 1/2" diameter on one end, and about 2 inches on the other? They make steering rack boots, the one on my Honda is smaller and is about 3/4-1 inch on both ends.
Colin
183
ON Canada
Mazda
Grab it from the junkyard, while you're there find a newer vehicle that has a similar boot and order one of them if you want.
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Hey, is this boot important? I'm thinking it probably is, to keep grit out of u-joint. Mine's starting to go south, just noticed that the other day.
But U-joint not prone to same kind of failure as when cv boot fails (diff vehicle) and salt/sand get in it then it is not long for this world.
To replace is it simply take u-joint apart? Or harder to do?
Colin
183
ON Canada
Mazda
