2020 Ranger (outside of gas station) refueling puzzle
James Fremont
Pacific
Ford Ranger XL
2.3 EcoBoost
225/70R16
Hi all,
This is actually more like a question for me...
A couple of days ago I was trying to refuel my truck (2020 Ranger XL) with a portable gas tank (the Fire Engine red Jerry gas can from Harbor Freight). This was the first refuel attempt outside of a gas station.
I struggled a long time and just couldn’t insert the nozzle into the refuel port deep enough to start a proper fueling as there is a locking mechanism at the base of the Jerry can nozzle that needs to engage (by seating and pressing against the refuel port mouth) to allow for fuel flow. When that failed, alternatively I then tried to use a plain old funnel with a pig-tail tube. That too, failed at the same problem – I was not able to insert the tube much beyond the fuel tank filler valve, maybe half an inch only.
The Owner’s Manual has a rather detail description and illustrations about the refueling system but I don’t see it mentioning anything about “adverse effects of inserting any objects other than fuel pump nozzles”, so I thought refueling from a portable fuel can should be doable. I tried to see what could be blocking the Jerry can nozzle entry by poking my finger into the port. Behind the filler valve (which is in plain sight as it is in place of a filler cap) I felt a flap blocking the passage. In normal fuel pump refueling the pump nozzle can be fully inserted rather smoothly so I assume this flap maybe spring loaded and will give when pushed. However, it would not budge by my finger’s pushing. I wonder whether there is some kind of interlocking mechanism behind the filler valve that prevents "unintended objects" from tempering or entering the refuel pipe. But as far as I could tell, a Jerry can nozzle is almost identical in shape and size to a pump nozzle.
Has anyone have the same experience? It is hard to believe that the refueling system is designed in a way so to deny refueling outside of a gas station. Admittedly, I haven’t really push the (Jerry can) nozzle hard to force its way in, fearing such an act might damage the system somewhere, but I thought I really shouldn’t have to if I do it right. This is my first encounter of such refueling system – a filler port without a cap - I think it would be wise of me to assume I did it wrong, but then, what would be the right way since I had no trouble doing the same thing with other vehicles ?
Any idea? Thanks!
don4331
1,353
Calgary, AB
5.3
My '17 F-150 has a custom funnel behind the seat. You insert that into the fuel filler, then you can fill from your Jerry can or whatever.
Don't know if Ford includes them on Rangers or in USA...
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Make gas cans pour again.
Remove the cap from neck and gas can........fat bastard funnel...
Sharky
154
PA
2.3 EcoBoost
most new vehicles have the anti tamper fuel filler set up, including the Ranger. check the owners manual for the location of the factory funnel
to fuel your Ranger (it is under the rear seat area). there are some aftermarket funnels that will work.
sgtsandman
Aircraft Fuel Tank Diver
12,764
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The truck should have come with a funnel for that. Super Crews have them behind the rear seat. Those are intended for just the situation you are trying to attempt. It’s a weird looking black funnel.
James Fremont
Pacific
Ford Ranger XL
2.3 EcoBoost
225/70R16
Thank you all, gentlemen, for pointing out the obvious.
Now I feel embarrassed, had I flipped back just a few pages when reading the manual I would have caught the rather plain text and illustration, a bad habit of mine - choosing to read electronic version of a manual over its printed copy for fast/pinpoint search capability.
Excuse me for the bother, and thank you!
rich
4
Fernandina Beach, FL
Nothing to be embarrassed about. By posting the question and having it answered, you've just facilitated the education of a bunch of idiots like me, and saved us from future road/trail-side frustration.
wildbill23c
577
Southwestern Idaho
215/70-R14
Don't feel embarrassed about not being able to figure out how to refuel from a gas can, be embarrassed that you ran out of fuel in a new truck with a gas gauge in plain sight JK LOL...
All that anti-theft crap on vehicles now to include the gas tank, yet vehicles are still stolen, makes it harder to work on your own vehicle is all it amounts to...certainly doesn't do anything to stop the thieves, who'll just drill a hole in your gas tank and use a bucket to catch the fuel...and since most fuel tanks now are cheap plastic....its even easier and safer to drill holes in them...that is if a rock doesn't puncture it first HAHA!!!
James Fremont
Pacific
Ford Ranger XL
2.3 EcoBoost
225/70R16
You don’t say…
I almost ran into that situation; the truck started warning me about fuel running low with a pop-up message on the information display saying “30 miles to empty”. Due to my circumstantial reason and also thinking that I could just count on the reserve fuel at home as back-up, I didn’t take it to the gas station and refuel at the first chance, I ended up watching the information display counting down on ‘miles to empty’ number to 4 when the truck stopped at the gas pump. I sighed a big relief and shut the engine.
That brings me to another question: there seems to be unspecified amount of fuel reserve in the gas tank, I wonder how much longer the truck can still run when miles-to-empty hit zero? Or, would it just choke on fume and quit right there since it did give plenty warnings?....
sgtsandman
12,764
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Better to just not touch the fuel reserve or learn the limits. Running the tank so low is hard on the fuel pump since cavitation can happen and it depends on the fuel running through it to keep it cool. Not to mention modern fuel injection systems don't like it when you run them dry.
