PFC Laird
- Jan 3, 2008
- 0
- UT
- Ford
- Engine Size
- 352FE
I was planning on this project when i got my leave after coming back from iraq. I'm pretty much clueless as to what would be the easiest thing for me to do. I've read through the tech library a few times but it'd be easier for someone to "break it down to me barney style". any input will help especially about a trans swap if i need one. (ive seen folks with lx mustangs use the same tranny with their v-8 swaps) and any supplementary add-ons such as brakes and such.
i have a 2wd 94' and a 4 spd w/ overdrive manual trans
this is the engine package i picked from proformance unlimited
Thank you for contacting Proformance Unlimited. Based on your request our recommendation is our Ford 289 engine package with 350hp. This engine package sells for $6,750 plus shipping. The following list of specifications will apply to this package:
A Precision Machined 289Block (Painted Color Of Choice)
A Precision Ground Micro Polished Cast Crankshaft (Optional Scat Crankshaft $200)
A Set Of Tri Metal Clevite 77 Rod And Main Bearings
Scat I-Beam Bushed Connecting Rods With ARP Hardened Rod Bolts
High Performance Speed-Pro Flat Top Pistons
Hand Filed Performance Rings To Match
Three Piece True Double Roller Timing Set
A Hand Selected Performance Cam Shaft To Achieve The Idle & Throttle Response To Customers Desire.
16 High Rev Lifters (Anti-Pump Up)
Dart Performance Pro One Aluminum Cylinder Heads 62cc With 170cc Intake Runners
(8) Stainless Steel 1.94 Intake Valves
(8) Stainless Steel 1.60 Exhaust Valves
(16) High Performance Valve Springs And Retainers (To Match Camshaft)
7/16 Screw In Studs And Hardened Guide Plates
Chrome Moly Push Rods
16 1.6 Ratio True Aluminum Roller Rockers
High Volume Oil Pump
Chrome front sump oil pan, and dip stick (additional $150 for rear or double sump oil pans)
Timing Cover With Scale
Engine Will Be Assembled With All New Bolts
Edelbrock Aluminum Performer RPM Intake Manifold
Chrome Thermostat Housing To Match Intake
Edelbrock Carburetor W/ Electric Choke (Upgrade To A Holley Or Demon For $300)
14" Chrome Air Cleaner
MSD Pro-billet distributor (Requires MSD 6AL ignition control)
MSD Blaster II Coil And Bracket
8 A/C Delco Spark Plugs
Custom Fit Taylor 8mm Ignition Wires (Color Of Choice Black, Red, Blue, Yellow, Green, Orange No Extra Charge)
Fuel Pump W/Inline Filter
Hi-Flow Water Pump
Chrome Valve Covers With Baffles
Professional Products Performance Balancer
Fel-Pro Performance Gaskets
All Engines Will Come With Flex Plate (For Auto Trans) Additional $200 For Manual Transmissions.
As We Assemble Your Engine We Take Several Pictures Throughout The Building Process. And Then We Send Them To You Via E-Mail, So You Can See The Quality Of Parts And Workmanship That Goes Into Your Engine.
Each Engine Is Live Run Tested Timing Set, Carburetor Adjusted For Optimum Performance.
We Video Tape Your Live Run Engine, And Send You A Copy.
All of our turn-key crate engines come with a 1 year warranty with unlimited mileage
Hi-Flow Water Pump
