2wd 351 windsor
jmkjr72
green bay wi
1992
explorer
im running a 92 ranger with a 302, efi. gong to swap over to a 351w. its a 96, full rollerized block possible aluminum heads.
what i know will work, oil filter relocator, dual sump pan, wiring (just chang over pcm)
needed to change. flexplate, torque converter, im runnin hedman conversion v8 shorty headers will they work? harmonic dampner. power steering needed to change?
all front end brackets and pullies will work. ive got about 6" of clearance to my elec fans so thats not an issue, but im using mustang coupe, 1988 motor mounts. sit pretty high maybe drop in smaller mounts? anyone else got any other input? thanks
Full Edit
Quick Edit
baddad457 Jun 4 2007, 11:02 PM Post #2
Working towards my 6th wrench...
Group: Members
All that you need change is the flexplate, the torque converter will be fine as long as you use the correct flexplate. If the 5.0 has a 157 tooth flex, you just need to use the same size flex but in 28/oz. Can't say on the Hedman swap shortys other than you've got em, may as well try em.
Full Edit
Quick Edit
projectnitemare Jun 5 2007, 07:14 PM Post #3
The Nitemare Lives
Group: Premium Member
Vehicle Make: Ford
Vehicle Model: Ranger XLT
Gender: Male
Vehicle Year: 88
2WD or 4WD: 4WD
No problems with the power steering or steering box. The headers probably won't fit. Good chance they will hit the frame at some point and the steering shaft, but if you have them try them ya never know. If you are saying the 302 pan will work on the 351, it wont'. They have different oil pans.
Full Edit
Quick Edit
AllanD Jun 6 2007, 08:34 AM Post #4
Abandon All Hope
Group: Members
Vehicle Make: Ford
Gender: Male
Vehicle Year: 1987
2WD or 4WD: 4WD
Yeah, the 1.2" of deckheight increase on the 351 plays merry hell with clearances....
AD
Full Edit
Quick Edit
brandon black Jun 6 2007, 08:38 PM Post #5
Too much time on my hands...
Group: Members
Vehicle Make: ford
Vehicle Model: std cab
Gender: Male
Vehicle Year: 1992
2WD or 4WD: 4WD
i believe the dual sump pan i have is off a 351 windsor?
probably have to modify 1 or 2 header tubes, they hug the block pretty good being shortys and go straight back pretty much off the head
Full Edit
Quick Edit
projectnitemare Jun 7 2007, 07:46 PM Post #6
The Nitemare Lives
Vehicle Make: Ford
Gender: Male
Vehicle Year: 88
2WD or 4WD: 4WD
The pass. side you should be fine with the headers, I have a set of long tubes that will fit on my pass. side. The driver's side is a mother. The steering shaft is directly in the way and then you have to weasle past the frame and by the front drive shaft. I have a pair of F-150 shorties I'm going to try to see how they fit, if they do that will make somebody's day much better when they get to the exhuast stuff.
Matt
Full Edit
Quick Edit
Lifted88Ranger Jun 7 2007, 11:21 PM Post #7
Just passing by.....
Group: Members
Vehicle Make: Ford
Vehicle Model: Ranger 351w
Gender: Male
Vehicle Year: 1995
2WD or 4WD: 4WD
Get a set off headers off a mercury mountaineer with a 5.0 thats what im using on mine and i have no prob with clearence at all. i have a 351w in a 95 ranger
This post has been edited by Lifted88Ranger: Jun 7 2007, 11:22 PM
Full Edit
Quick Edit
bowturkey Jun 18 2007, 11:04 AM Post #8
I like this place......
Group: Members
Vehicle Make: FORD
Vehicle Model: RANGER EXT.CAB
Gender: Male
Vehicle Year: 1992
2WD or 4WD: 4WD
Do you have a 3in. body lift? I have a 92 ranger i"m collecting parts to change it over from a 4.0 to a 351 .
Was going to do the 302 then i had a friend GIVE me a 351 so i figured why not. I have a 4x4 with a 3" lift so it should be a little easier . Allways collecting info to. I'd like to do a mock setup first but don't know if it's worth the extra time.
Full Edit
Quick Edit
RANGERSVT Jun 24 2007, 08:35 PM
Go to your local autoparts store and get a pair of 71 truck motor mounts, they are no mod direct bolt on bolt in mounts for the 5.0L ranger, are about 12 bucks a piece, and are lifetime mounts at autozone...( AutoZone part number 2829 )
This post has been edited by RANGERSVT: Jun 24 2007, 08:36 PM
Are you saying the mounts of a 71 pickup with a small block will bolt a small block into rangers?
What years?
Full Edit
Quick Edit
krolop Jun 28 2007, 07:52 PM Post #12
New User
Group: Members
Vehicle Make: Ford
Vehicle Model: F350
Gender: Male
Vehicle Year: 1986
2WD or 4WD: 4WD
Occupation: Printer
Hey man I'm new here but was just wondering why you wouldnt want to just build a stroker with your 302 block? Same external dimensions, plus you can make tons of torque with a nice 347. Just something to consider. The reason I made an account here is because my buddy at work is in the process of assembling a 347 for his '94 4x4 and needed some help with the technical stuff.
Full Edit
Quick Edit
odie1969 Jun 28 2007, 09:38 PM Post #13
Been here a while
Group: Members
Vehicle Make: ford
Vehicle Model: ranger stx
Gender: Male
Vehicle Year: 1987
2WD or 4WD: 4WD
QUOTE(krolop @ Jun 28 2007, 05:52 PM)
Well why not stroke a 351w, you can make a hell lot tq with a 426W
Full Edit
Quick Edit
brandon black Jul 12 2007, 12:07 AM Post #14
Group: Members
Vehicle Make: ford
Gender: Male
Vehicle Year: 1992
2WD or 4WD: 4WD
sorry guys havent posted up due to computer problems. but back now. well the 351w would be very nice stroked out to a 426,ie no replacemtn for displacement,
