3.0 to 4.0
Nitrosnoopy
What do I need to grab beside the wiring harness and computer ? The swap is being done on a 95 ranger. What about the gauges ? Is there anything i need to know?
Wicked_Sludge
44
Westport, WA
3-point-GO
transmission, probably the y-pipe. if your going from OBDII to EEC-IV or vica versa, it could be tricky.
Nitrosnoopy
What years had the eec and which had the obd?
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Both are EEC, the question is WHICH EEC....
up to 94 Rangers were EEC-4
95-up are EEC-5
(the numbers are usually expressed as roman numreals , "IV" for 4, "V" for 5)
OBD-2 was "On Board Diagnostics", the two represents the second
attempt of the government to force standardization, and while more
successfull than their first attmpt was still something of a failure in
"standardization".
For what you are doing you essentially need the entire underhood
harness and the compute, and yes, you need a Y-pipe as well.
Good luck finding a manual 4.0 computer for a 1995, they are
kinda hard to track down (I have one "loose" but only because
someone wanted it then changed their mind after I got it)
AD
