3.0 vs 4.0 Which is Better?
dmt
PA
4 cyl
I did some searching on this issue, but could not find what I was looking for. What is the difference between the 2 V6's that Ford has in the Ranger. Is the 4.0 designed for more hauling and the 3.0 for better mileage?
I'm in the market to get another one and not sure which route I should/would go. I mostly use a truck for small jobs (picking up a Christmas tree, load of mulch etc...). I figure I will go the 4 cyl route, but is there benefit to a V6 besides more power like it being a more reliable engine?
Thanks
3literEarl91
Fairborn, Ohio
I have a 3.0 and it has never given me a bit of trouble. it has over 300000 miles and does not use oil and makes no noise other that my exhaust. I have had no exp with a 4.0 but from what i have learned here it is not a bad motor either.
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
I've owned both (still have the 4.0l ranger), the 4.0l has more torque, but the 3.0l got 2-3mpg better. They both had about the same mileage (120k+) on them when I drove them, the 3.0l used a quart of oil every 1,000 miles, the 4.0l used a quart every 4-5,000 miles, but that could all be how they were maintained/driven before I had them.
What year truck do you plan on buying? Personally if I were to buy another Ranger it would be a '02+ standard cab with the 2.3 duratec and a 5-spd.
Ranger44
23
Illinois
FORD
4.0 OHV
Depends on what you want in a truck. You want a workhorse you can use and abuse, or a reliable daily driver that can stil pull a little weight around? After you decide, the choice would be obvious.
4.0~ Has it's quirks. Has some head issues. The stock castings like to crack(most likely after overheating). The push rods have a wearing problem also. These issues can be solved by aftermarket cast heads and hardened push rods and rockers. Nice 10" clutch. Gets ok mileage(20mpg) and good low end torque.
3.0~Was a good/fresh design from the start. Doesn't have a too many problems. Known for lasting a long time....IF you keep it well maintained. Known for it's higher powerband. Very good cruiser. Get's about 23-24mpg.
dmt
PA
4 cyl
That would be ideal if I am able to find in the $3k and under range. I am currently looking and when I find a deal I cannot pass I plan on buying. I figured I would get the lowdown on the 3.0 and 4.0 in case one pops up.
97ranger4x4
Sacramento
Yeh I am very happy with my 4.0, but for being a Daily driver, it often has more power than necessary. I have towed with it a few times, but I could have avoided that had I had a smaller V6. I do like the torque of the 4.0. I ususally keep it below 2500 rpms to keep mpg reasonable. Mine will drink fuel if its above 3k. the 3.0 seems to be a rev-happy motor. Not ideal for towing, but for you, it will be more than enough. I say go with the 4cyl. The gas mileage will certainly be worth the "benefits" of the V6's!
lil_Blue_Ford
6,229
Butler, PA, USSA
4.9L
If you're buying something older than when they introduced the flex-fuel 3.0 (I think that would be pre-98), I'd probably look for a 4.0L for hauling duty. Although I have no personal experience with the 3.0's of that vintage.
For hauling, IMHO, I love my 3.0L with a 5-speed. It's pulled everything I've ever threw in the bed or hooked to it. Would be nice to have a lil more low-end grunt, but it gets by. Heck, I get 15 mpg highway towing a Bronco II behind me with it!
That's what just over a ton of 2B limestone looks like in the bed... hauled it just fine. Of course, I had to upgrade my springs to a custom leaf pack not too long after that... guess stock Ranger springs are made more for weekend warriors rather than someone to use it like a truck all the time...
thegoat4
6
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,868
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
The 4 cyl is dead reliable as well. For light hauling a v6 isn't worth the gas mileage penalty.
Also the 4.0 is not real common in 2wd Rangers. It was available but you won't find many. Probably half the 4wd's you'll find will have a 4.0. A lot of 2wd's will have the 3.0, especially in Supercab models.
Hawker
I had the 3.0 supercab new in 02 until I bought the 08 with a 4.0. I think the 3.0 was a fine engine and worked well in the the truck. Had a bit of a power limited situation loaded going thru the mountains in WV, but generally always gave me 23 -25 mpg. Mine had the towing package and 4:11 rear end which kept it cranked up pretty tight at speed, but it never seemed to bother it. I never had to add a drop of oil between 5K mile changes. The 4.0 gets 21 mpg consistantly and doesn't use any oil either (I only have 12K on it now). It seems uneffected by loaded or not and I believe it can handle about anything you would throw at it. Back in 96 I had a 4 cyl 5 spd. and that was troublefree as well. So my answer is that there's no wrong choice if you find a nice truck.
russjd
3.0 vs 4.0
4.0 is the best pick...
3.0 vs 4.0 mpgs about same...
the 3.0 is ~same power as 2.3 4cyl !
so its a no-brainer
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
holy necro bump.
txgocartB3000
San Marcos, TX
Mazda
What's 6.5 years between friends?
Ray
