Found! 3.73 D35 TTB
manley
4
Richmond, IN
2.9 swapping to 4.0
Wut?
Location Richmond, IN - looking for a complete D35 TTB with 3.73 gear. Sold one years ago thinking I would never need it.... that was dumb. I'm swapping out the D28 in my 87 Ranger.
901wd#2
11
Vermont
Ford ranger
manley
4
Richmond, IN
2.9 swapping to 4.0
Wut?
Thanks, but unfortunately, he's not selling the shafts and other parts. I need everything.
2 bronco 11s
66
kentucky
ford bronco 11
Have you tried car-part.com ?
2 bronco 11s
66
kentucky
ford bronco 11
I’m 4 hours away also . Got a 93 ranger and a 94 Explorer. Not sure of ratio in the Explorer . But Ranger is a 3.45 . Good luck .
red_ranger50
4
Diamond springs Ca,
4.0ohv
1.25in
I can sell the diff and extra parts with it all. It would have to be pallet shipped if your not local. I have the beams and radius arms. Diff. All axles. Single caliper knuckles. And auto hubs. Only think i dont have still is the spindles. But i manufacture and sell aftermarket manual hub nuts also
Josh B
1,988
Oklahoma
what in hel is a TTB ? :D
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,547
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
TTB = Twin Traction Beam
Josh B
1,988
Oklahoma
I have no clue what's in the 96 Explorer, I didn't get that far before the transmission went out
Josh B
1,988
Oklahoma
It has a heluva sway bar in it
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Yes, its IFS. Aka SLA: Short Long Arm. They are an A-arm suspension with the upper A-arm longer than the lower to help keep better camber in suspension travel.
Uncle Gump
Token Old Guy
13,547
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Actually... the longer arm is the lower.
They also use a torsion bar as the "spring".
