riverjig
- May 15, 2008
- 1
- Age
- 45
- Ford
I have had this misfire on bank 6 for some time now. I have replaced the fuel filter, replaced spark plugs per man. spec and gapped correctly, have replaced coil pack, and wires. I now have P0305, P0306, and P0174
Its bank 5 and 6 misfire and bank 2 running too lean. My truck has no horses now. It obvious why but its ridiculously underpowered. When i stop at a light or when I get home, I smell fuel for some time. Ive tried to visually inspect for fuel leaks, but i feel I might be wasting my time. Im not sure what to do anymore.
I also noticed im getting roughly 10mpg. this is horrible. This is now beyond my expertise. I HAVE done some pretty extensive research on this forum and have read numerous things from vac leak to cat is clogged. With all three of these codes grouped together, Im curious if thats not a red flag for some of you pros out there.
I also, in trying to alleviate the bank 6 misfire had the injector replaced a couple months ago. That turned out to be a waste of money and am now set on doing as much as humanly possible myself. The bank 6 code came on shortly after replacing it.
Any suggestions would help. I also read compression test?
