351 pics
littleme13
does anyone have any pics of the engine bay?? prefered early 90s rangers. from the front and top would really help. i need the sides more then anything. im trying to get an idea of where to stuff a few turbos.
HoleshotKFX400
Fleetwood PA
307.5
Good luck, If you would use say fox body exhaust manifolds, flipped around you could probably do it
littleme13
my headers are going to be custom made to handle 4 t3s so anything stock wont work. its crazy i know but its gonna be bad azz when im done. i recently moved and dont have a garage so its kinda hard to start my build untill i get into a house with a garage. so for now its desktop building hence why i need the pics.
BlackBII
Ranger Custom
Truck of Month
984
UT
It'll be tuff to fit 4 turbos and a 351 in that engine bay...
projectnitemare
8
Osceola Mills, Pa
396W
You won't have any room in the rear of the engine bay, it is guranteed to be in the front but that's even tight. You might have to use only two or place them under the truck and run longer boost tubes and such. I'll look to see if I have any recent pics on my computer.
Matt
littleme13
what im hoping to do is replace the brake booster with one from a mustang and completely remove the heater box in hopes of making as much room as possiable basically anything that doesnt need to be there isnt going to be. i know its gonna be tough but so is running a dual sequention turbo setup, my dreams are high but thats what makes it fun.
projectnitemare
8
Osceola Mills, Pa
396W
Here are some pics. A few things have changed in there since these were taken but that can get you a ballpark idea. This is with a 3in body lift.
Matt
littleme13
thanks very much matt these were the kind of photos i was hopeing to get. from what i can see the biggest problem is going to be the drivers side and that stupid steering shaft..lol who really uses those. hmmm... maybe i can find a way to reroute it or something who knows. how did the zf hold up behind the 396??
projectnitemare
8
Osceola Mills, Pa
396W
The ZF holds up ok. I'm still waiting to hear it explode; this engine really is a little too powerful for it. When I can get the truck to actually hook it will pull the left front about a foot off the ground, when it doesn't hook it will spin the tires though 3rd gear. I like having a 5 speed but I miss the super fast shifts my C4 had. Don't miss blowing it up all the time though. A C6 is the way to go if you are making big power.
Matt
HoleshotKFX400
Fleetwood PA
307.5
To gain some extra room with that steering shaft, some dude over @ rangerpowersports.com put a 4.6 in a ranger and i believe he moved the steering shaft outside of the frame using some nissan parts or something of that sort, if you go poke around you'll probably find the thread... I wanna see some pics of this build then :)
littleme13
hopefully the build will be underway soon but it seems all my plans fell threw when i moved so im looking for garage and a truck but most of the plans are done just throwin a few ideas around and trying to work out a few efi things. the motor will be a 351 stoked and bored to 427 most likly c6 and 9in rear narrowed to be slighlty skinnier then stock. dual sequential turbo setup using the t30s. gutted but only as much as i can and still look stock. :) going for the sleeper of the year award..lol:)
Sunk
125
Everett, WA
3.5 Eco
Sounds like one hell of a build. I'm waiting to see it.
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
you need to talk to 281 ranger. he is the guy with the 4.6. he used all ford parts iirc.
projectnitemare
8
Osceola Mills, Pa
396W
He used the the stuff from the donor car if I remember right. I want to say it was a lincoln mark III. Most likely with the turbo stuff you will have to shoot the exhaust to the front, that will solve the steering shaft problems for the most part. From there run the exhuast over the frame and out toward the rear. I'm sure it will involve some creative thinking.
Matt
littleme13
this is gonna be an endever thats gonna be lots of fun. ill keep everyon posted hopefully if everything goes right soon after the holidays ill start the tear down then its just a build up from there. thanks for all the info and the help guys.
