4.0 crankshaft sensor
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Probably not . 94 would be ODb1 and the 96 is OBD2 Type the part into a parts list and check the part numbers.
californicated
sunny southern california high desert hesperia
hey thanks andy i am in the final stage i hope of a 94,96 engine swap, the motor bolted up no prob, had to change wire harness and cam shaft syncro the engine fired up no prob then set off 3 codes i dont have time to explain as of now...... i am changing the crankshaft sensor soon like as soon as i finish typing both crankshaft sensors look identical i will brb
