4.0 OHV Conversion
Kingoverace
Jersey
EFI 5.0
So I've got a single line fule setup with a evap canister hooked up.
I just dropped in the 40 which has 2 fuel lines coming off the motor.
What would ya'll do?
Kingoverace
Jersey
EFI 5.0
Debating on putting in a older style fuel pump and ditching the evap canister and just run 2 lines?
3,614
OK, Evap canister doesn't get ditched and doesn't go inline with the fuel lines.
Best way to do it is find the lines you need in the junk yard.
Kingoverace
Jersey
EFI 5.0
umm...adding lines insn't an option with the current fuel pump. the pump on the 98s have 2 spouts...1 is to send fuel to the motor, the other line goes directly to the evap. Getting the lines isn't the issue here...Its figuring out how to get 2 lines into the tank like the motor was intended.
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
Get an older tank and pump.....
-PlumCrazy
snoranger
Professional money waster
ASE Certified Tech
13,731
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Go find a 98+ 4.0l engine and steal the returnless fuel lines (from the frame to the fuel rails) and swap them in.
Kingoverace
Jersey
EFI 5.0
-PlumCrazy
I feared that's what is going to have to happen...Just wanted to hear it from someone else.
I'm going to boneyard to see what vehicles have what setup. Motor came out of a 96 Xploder o I guess i'll have to start with them.
