4 in lift kit installed
johndough
11
Virginia
Ford Ranger XLT
I bought this 88 extended cab 4wd and it has a 4in lift. I'm thinking that the last owner who installed it only bought lift blocks and shoved them under there because whenever the truck hits a bump or anything you can feel it rough. How can I tell if all he did was put lift blocks underneath it? Also is there any way I can tell what brand lift kit was installed? I also installed rough country N3 shocks and it didn't seem to make much of a difference in the ride. Maybe a little bit but not what I was looking for.
dvdswan
2,908
Seattle, WA
Ranger XLT 2WD
In the tech library they show the different lifts installed. You might be able to identify yours through that. Otherwise, take pictures and post them here and someone might spot what you have.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Usually rides better with worn springs.
Blocks can be stacked....that is a cheap lift ...
Factory blocks generally have built in bump stops.
Pictures are golden here
ericbphoto
Overlander in development
16,755
Wellford, SC
6"
Ok. Not a great picture. But here is a view showing OEM blocks with bump stop extensions on a 93 splash.
