4x4 light not working
McFuzzie
Vancouver, WA
4.0 L V6
Hello,
When I shift into 4x4 High the little "4x4" light on the dash board will not come on. This happens when I shift into 4x4 Low also, but the "Low Range" light comes on. I've checked the fuses and none of them are bad. I'm pretty sure my 4 wheel drive isn't broken because when I shift into 4x4 H it drives different. So what could be the problem? I have manual locking hubs and I don't have the push button system. I also have a 4.0L engine.
Thanks,
Kyle
martin
26
St Bruno, Quebec
1991
perhaps the bulb is burned?
sfwjesse
New Hampshire
Thats the first thing i would check....my old B2 used alot of those little tiny bulbs in the dash and 3 of them were dead when i bought it.
The next thing to check would be the switch that senses you are in 4x4....im guessing there has to be one somewhere on the transfer case or shifter.
McFuzzie
Vancouver, WA
4.0 L V6
Did you end up changing them? I popped off the trim around the dash board to check the bulb and I can't reach it. It looks like I have to take out the whole instrument cluster just to get to the bulb. Do I have to do that or am I over looking for something?
snoman6115
Weston, WI
v6 4.0
no u do. on my 98 its pretty simple idk bout older models tho
