- Sep 6, 2013
- 1,354
- Calgary, AB
- Ford
- Engine Type
- V8
- Engine Size
- 5.3
@vigness : You would be looking for a Jeep Cherokee (XJ) from mid '85 through 2001, 2 wheel drive. You're looking for part 10 (2x).
I originally assumed Edge Rangers were set up this way, until @adms08 set me straight - that Ford made a 3rd knuckle which was hybrid of 4wd and 2wd that allowed both the torsion bar spring and the 2wd hub.
But as @Uncle Gump reiterated, if you don't plan on fixing the front axle, pull the 1/2 shafts apart and just insert the outer cv hub. (I'd undo the 3 bolts for the axle and 6 at the transfer case and reduce weight of truck by a hundred pounds or more for the axle and front driveshaft).
