Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
im only trying to figure this out because i got a cbr trans cooler with a 12" spal fan, and i need to hook up the temp send for the fan on the exit line, so are you sure the top line is return?the top is the return. Ford's don't have a check valve in the lines so you are ok and a cooler normally doesn't care which way the fluild is going through it. Slight chance you could dislodge some built up junk in the cooler but that's what the filter is for right?
That shouldnt work with a 5r. It has an internal thermostatically controlled bypass... It wont flow fluid until its warmed up.I know this sounds stupid and messy but take a transmission line off. Have someone start the truck and see which way the fluid flows. As soon as you see which way it flows have them shut it down. It may work too with a starter button on the soleniod and just cranking it motor over. If I knew the answer I would sure tell you but unfortunately I don't, and this was the first thing that came to mind.
I knew Dale had tested it.... So it only took me about 1 minute of searching.Thank you lord I've been searching for weeks never thought to check the expo forum.
