trader007
- May 22, 2010
- 2
- Ford
5r55e rebuilt tranny and its almost right but not quite *Update! Info!
FIXED!
talked to the shop that sold me the tranny. they said to try swapping out the sensors on the outside of the tranny, because different years had different ohms across the terminals.
swapped sensors, and checked ohm while doing it. the same. and of course, it didnt fix the problem.
got a little frustrated, then decided to just put the old valve body on the new tranny. BINGO! it runs slick as sh*t! i can floor it now and it will still shift right to 2nd when its supposed to. and overdrive works perfect too! this tranny shifts so smooth it almost feels like a constant velocity one
i am going to call those guys and see if they want to fix this rebuilt valve body- or at least figure out why it didnt work right.... heck of a lot better shipping that then the whole tranny back!!!
original message------------------------------
so i bought a rebuilt 5r55e for my ranger. installed fine, and it does work OK.
1st problem-
when i give it some good pedal, it doesnt want to shift out of first. just goes until it hits about 4krpm then it slowly shifts to second and eventually settle in. if i just drive normally, it shifts on time but it does shift into 2nd gear fairly hard. it also likes to kick down to 1st hard when im slowing down.
2nd problem- no overdrive. when i get going fast enough that overdrive would normally kick in, it doesnt and the o/o light flashes. im still not sure if this problem is intermittent, because it doesnt seem to happen right at first... it usually takes a few stops and starts before the o/o starts flashing. it might be related to problem #1 is what im thinking... the upper 3 gears shift so smooth its hard to tell when it happens... i have no rpm guage (it works sometimes, but rarely)
anyone familiar with 5r55e rebuilds, and what might shops choose to ignore that would cause my problems? other then those two things, the tranny does feel really REALLY tight. it feels brand new. so i can tell they did some things to it, im just not sure if they did a full rebuild...
FIXED!
1st problem-
