60 psi on all cylinders
corbons87ranger
Cortez colorado
Ford ranger
So I bought a 1987 2.9l V6 Ford ranger XLT from an auction last year and I found it to be a little bitty of a piece of junk before diagnosis. It had a major knock which I had found to be a lofter rod that fell out of place and almost sliding down to the oil pan. After fixing that I did a compression test on all six cylinders and found all of them to be 60 psi. Is this normal or is this an engine ready to be overhauled or take. To the scrap yard?
alwaysFlOoReD
5,131
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
60 is very low
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,527
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Depends on how you ran the test?
We're all plugs removed?
Was throttle blocked open?
Did you have a charger on the battery for consistent crank speed?
Fuel system disabled??
60 does seem low... but its consistent.
fastpakr
2,841
Roanoke, VA
Do you trust the compression tester? If you don't know that it's good, borrow another and retest one or two cylinders.
rusty ol ranger
2.9 Mafia-Don
7,611
Michigan
177 CID
Yes.
If you got 60 on all 6 id try a different tester.
90 is required to run.
corbons87ranger
Cortez colorado
Ford ranger
I did a cranking compression test on it. The throttle was not blocked open. I did have a charger on the battery. But the fuel system was not disabled I just disabled the coil.
SenorNoob
589
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I'm prepping for a swap because I have 5 cylinders at roughly 90. If all six were at 60 I can't see it running. And the throttle being closed will cause that.
rusty ol ranger
2.9 Mafia-Don
7,611
Michigan
177 CID
It still runs but when given to much gas by the pedal it just stumbles and chokes
Id get a known good gauge and open the throttle and try again. At 60psi im 99% sure it wouldnt even fire
corbons87ranger
Cortez colorado
Ford ranger
Everything still runs great so I think that the pressure tester I was using wasn't the best.
