79 302 With M5OD-R2 TRANNY
bowturkey
Freedom N.Y.
FORD
4.0 Plan on 302
15”
I'm going to be using an older 302 with 28oz. Balance and the tranny is as M50D-R2 with the hydraulic clutch. Should I use the clutch plate and pressure plate for the older setup or the newer like say 90-92 ? Don't know if the older clutch and pressure plate would work with hyd. Clutch setup.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
You need the older flywheel, but newer clutch kit to fit the year of the trans...
SVT
bowturkey
Freedom N.Y.
FORD
4.0 Plan on 302
15”
Thanks! That's what I thought was just checking to make sure.
