Ok, I've had some requests for build photos
Here is the donor truck 89 dodge 3/4 ton 4x4 114K miles had brand new 727 in it PO had a little oops in the snow. I also bought a nv4500/ transfercase, bell, clutch etc from the same guy for $300! It came from a 96 he parted out.
here is the other doner truck 85 F350 4x4 dump POS 351w/ 4spd I chose this truck becuse I wanted a 4x4 for dually which wasn't available untill 84. PA is strick on inspection laws so I didnt want to make a 2wd in to a 4wd. Also being I was swapping a 5.9 I needed to be imission exempt (9,000 GVW-up) and I knew I wanted a dually so this worked nice instead of making a 79 f250 into a dually I am a legal heavy weight class and immison exempt.
after teardown
sold the 727, np 205, doors, gate, seat, both axles fuel tank. Ended up getting the motor for almost free! :shock:
another teardown photo. Sold motor & trans scrapped cab & bed got frame & axles for free!
painting up frame and swapping rear axle. The dump had a chipped ring gear and open carrier plus some broken leafs so I bought another f350 for the posi rear and new rear leafs.
got a set of alum wheels for it at a local junkyard but they didn't come with the lugnuts. I ended up paying $4 per lug nut ouch! Either way they look alot nicer than the rusty steel wheels that were on it.
trying out my new 79 Ford body. It took a couple mods to make it fit but it wasn't too bad.
I chose to put the body on first because I wanted to center the wheel in the wheelwell and get it all bolted down then I could modifey for firewall clearance if needed.
next it was time to start fitment, I used the stock dodge rubber mounts from the 89. I then slotted holes into the large engine crossmenber in the Ford frame and the motor sat right down in level and I didn't have to do anyother mods other than trimming the excess bolt the stuck through the bracket for the tracbar on the rear of the crossmember so I had proper oilpan clearance.
I had to pound the firewall in a little for valve cover clearance it could have been elliminated with a body lift but being this is going to be a work truck I wanted it to be stock height. I then stripped cab a prepped for paint.
Cab was edged in including the firewall. The motor was then painted and put in then the front clip was put back on for the final time.
Everyone always asks why it is CAT yellow.
The motor was supposed to be Cummins Gold but when the paint dryed it turned yellow. We thought it was funny and desided to leave it alone because it would really confuse people when they looked at the motor.
Then it was time for paint.
Time to put it back together
