oddball101
- Jun 8, 2010
- 0
- Columbia SC
- Ranger
- Engine Size
- 5.0
I have an 8.8 swap using the same stock SUA configuration as the explorer and the sky jacker drop hangers to level out the lift to avoid raking. I yanked the leaf springs from the explorer but didn't anticipate the driver side sag and since have been to the junk yard 3 times trying to get the correct leaf spring. First trip I learned about the different spring rates that exist for different model explorers including what to look for with tow packages after searching.
When I had the two original springs sitting beside each other I noticed that one stood a little taller than the other but figured once bolted in place the torsion strength would still be the same - First mistake hence the sag.
So now I have been searching the net for info and I have found some good stuff from the listed links below but still have the issue.
http://216.198.221.184/forums//showthread.php?t=70062
http://www.explorerforum.com/forums/showthread.php?s=&threadid=13324
http://www.ford-trucks.com/forums/26144-factory-tow-package.html
So now as it stands, the good spring on the passenger side has a code of
"F87A PA
BOCO 227"
... and I have tried several times to get another passenger side spring of the same quality but with no luck. A couple of the spring codes from the other leafs I have tried are as follows:
"F57A FD
EC6 234" (which I thought was a winner coming from the pass side of a 97 exploder with a stock tow package and LSD, but still no good)
"F87A PA
OH8 245" (no good)
So right now I am game for suggestions one which vehicle to spot or whatever else I may need to look for. I also picked up a couple (what look to be stock) lift blocks form a 4x4 ranger but I don't think I could use those because of the bolt spacing pattern.
Any suggestions or insight is much appreciated...
Thanks
"F87A PA
BOCO 227"
"F57A FD
"F87A PA
OH8 245" (no good)
Thanks
