83 ranger manual brakes to power brakes?
rab
merkur
im looking at buy a 83 ranger, it will get a 2.3 efi turbo swap.
it has manual brakes, i want assisted ones.
what are my options on booster and m/c's, any oem/stock upgrades, what years came with what.
rab
merkur
bump for a list of sizes of boosters and m/c offer on rangers from 83-present and which is a direct bolt in for a 83?
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
Grab a pedal assembly from a 83-88 truck with power brakes, grab a dual diaphragm booster and M/C from an 89-92 truck. Remove your M/C and pedal assembly, toss in garbage, Pull two bolts out that will be right below M/C in firewall as well as the cover plate that's there. Install booster, and power brake pedal assembly. Install M/C, bleed brakes.
rab
merkur
so the 89-92 booster is bigger/ more assisted than the 83-88?
i will need a pedal cage from a power brake truck, my stock manual brake pedal cage will not work with the power booster?
Flit-e
11/2012 STOTM 04/2014 MTOTM
MTOTM Winner
Wyoming
Twin Turbo'd 393w
hey rab where are you located i have an 83 with power and i need to go manual..maybe a trade?
rab
merkur
Flit-e
MTOTM Winner
Wyoming
Twin Turbo'd 393w
would you be interested in selling your manual pedal assembly?
rab
merkur
allnpt0
Bedford, IN
Yes, they are different. The pin that the rod that connects to the manual pedal is located about 1 - 1 1/2 inches higher up the pedal than power.
Pete
rab
merkur
Pete
thanks
rab
merkur
will a pedal cage and booster out of a 90 4wd work for my 2wd 83?
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
The booster will work, I'm running a 91 booster in my 87
The pedals themselves are slightly different
The pedal cage from n '83-88 is completely different from that used on a 1991-94
AD
Insanejughead
33
Missouri
'94, '86
2.3T
Rab, just trade Flit-e pedals and ask (or pay) him to mail you his booster, too.
You won't need a new master cylinder, unless yours leaks bad.
Hell, you won't even need to bleed your brakes once you add the booster and change pedals.
rab
merkur
o.k. so...
83-88 power brake pedal cage is different than the 83-88 manual brake pedal cage.
and the 90-93 cage power or manual are different than any 83-88 cage.
my truck is a 83 with manual brakes, a 4 speed with 2.0 carbed motor, so to go to power brakes on my 83 i will need a 83-88 power brake pedal cage.
