87 4x4 manual swap crank no start
green'87-4x4
Santa cruz
Ford Ranger xlt
Hello all, new to TRS. I bought a project 87 with the 2.9l engine. The previous owner threw lots of money and parts and couldn't get it to run. Even rebuilt the engine. I've discovered through a vin search that it was originally an automatic. Odometer indicates it hasn't driven in almost 10 years. And there's been multiple owners who have swapped trans, built brush guard, rebuilt and swapped engines etc.
So I bought I bit of a mess but I'm hoping I have more patience than the others and can figure this out, get it running and use it as a farm truck in California.
The PCM has a sticker on it that says for Taurus and Sable 3.0 only.
Can I trust this? And assume I need to buy a manual trans pcm for 2.9? I've never seen another PCM to compare to.
Any other wiring details that may be missing I'd love to hear about it.
New from previous owner:
iac valve
Air temp sensor
Aftermarket Coil
Distributor
Aftermarket Injectors
Work done by previous owner:
Two new catalytic converters
Rebuilt engine honed cylinders
Resurfaced heads
Pulled hair out (assuming)
Spent $3000 in parts and machining
Since I've had it:
I bypassed a melted connection to inertia switch.
Checked Fuel is coming to rail
Has spark
Corrected 180 out distributor timing
Cleaned out throttle body
Going to replace TFI mod today
I'm aware that cam timing might be 180 out. Good thing it's non interference.
Any tips and things to double check would be greatly appreciated. I have read lots of threads but figured I'd start one anyway.
Thanks for reading
SenorNoob
627
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
3.0 PCM is definitely wrong, but; depending on year might be close enough? Early EFI is pretty primitive. If it's for a 3.0 with distributor and MAP or MAF (whatever the truck has) it should work to start if the wiring is the same. That's a whole lot of ifs though. Especially considering there are a few in junkyards within a short drive from you, at least according to https://www.car-part.com/
green'87-4x4
Santa cruz
Ford Ranger xlt
Thanks for the fast reply!
And for the link, I was looking for old rangers nearby but couldn't find any. Found the right pcm with that link and got a PCM monday. I peeked inside and the board looks clean.
Plugged it in and also replaced TFI module, it almost started a couple times really stumbling but couldn't get it going. I was getting excited! But After spraying starting fluid it wanted to start even less, no stumbling just cranking.
So Seems like ignition issue although it's all been replaced new. Gonna try the ect sensor next to see if that's got it running too rich.
I'll update as I go.
Thanks
