machinist
- Dec 18, 2008
- 1
- lyndonville, ny
- ford
- Engine Size
- 3.9
hi all, I recently purchased this beautiful 88 2.9 5 speed 2wd from my brother who only owned it for about a month. the kid he bought it from, drove it for about 2 years and then had an injector problem so he replaced the injectors with brand new injectors and the truck ran fine for a week before it got to the condition where it is in now....(one thing the kid said is that he had rust in the injectors and thought that the injector manifold was too rusty so he sprayed some sort of blue adhesive into the manifold in attempt to try and seal the rust)
When i start it, it will run for 1-10seconds and die. my brother took the rear tank(front tank has a leak) pump and sending unit out and everything checked out fine. he replaced the fuel filter and nothing changed. he checked the fuel pressure and says it is to spec.
I pulled the fuel rail "manifold" and injectors to take a look and found that indeed the fuel in the manifold was darker than it should be and dripped it onto a paper towel to see what it would look like when it dries and it left big rust colored spots. i found the return line was almost completely blocked off by that spray adhesive. so i cleaned what i could and reassembled the truck and the condition did not change.
I found a performance shop that specializes in tuning that will bench test the injectors and return them to new condition if they are clogged with rust or blue crap for 70bucks. i found a junk yard thats 3 hours away that has 3 2.9s in their lot and says they will pull a fuel rail for 28 bucks( i told them to go for it 5 days ago but have not heard back from them)
I am not afraid of spending 100 dollars on this truck because i paid only 300 for it! however i want to be certain that im heading in the right direction and not just throwing money at it unnecessarily.
Please let me know what you all think.
-rob
-rob
