88 2.9 to 94 3.0 swap
CAD
Greeley, CO
2.9L
have a 88 4x4 ext cab fm146 that gave problems lately, found that the head on the pass side was cracked. have a 94 4x4 stand cab m50d (runs and shifts good body , interior is totally trashed - 88 is perfect body and interior) was wondering if i could pull the engine and trans and drop into my 88. will the motor mounts, tranny mounts be the same? will use the rear ds from the 88 as length is different. and will i need to change the wiring harness?
Can these be swapped out with the engine and trans togethor or will i need to seperate them? any help would be appreciated, need to get it on the road asap.
TheChimera
Minnesota
2.9l V6, soon goin bigger :-)
IIRC, the 3.0l doesn't have the same bellhousing pattern as the 2.8/2.9/4.0. As far as the motor mounts and such, move them over with the donor drivetrain. Best bet would be to pull it all out together and swap it into the 88, then use whichever driveshafts fit. You may need to mix and match a couple components like yokes for the universal joints (transmission output shafts/differential pinion flanges may not be the same), but none of it seems over complicated if you're good with a wrench, books and bloody knuckles. :icon_welder: Best of luck.
CAD
Greeley, CO
2.9L
well everything seemed to work out OK. Found a Guy that had a good 2.9 engine (60,000 on rebuild) but rolled truck. He got a good m5od trans from a 97 Explorer sport and I traded him for my 94 good 3.0 engine and trans. Still a lot of work but at least I didn't have to change a lot, pretty much plug and play. Saved all of the floor plates from the 94 and all looks good. am bleeding the master and slave tommorrow and should be on the road tomorrow night if all goes well.:yahoo:
