88-97 5spd transmission/manual transfer csae gear boot.
mtnrgr
758
California
6" Skyjacker, with 1.5" coil spacers, custom radius arms, custom traction bars
31x10.50
Lord God is my guardian
I recently found this at a pull a part and figured someone here could put it to use. Only paid a couple of dollars for it. It is free for whoever can use it. Shipping should be cheap as it should fit easily into a priority mail box. I Cleaned it as well as I can. No tears in the boot and the base is good. On the bottom a few screw holes are cracked..I have done this on mine. I used slightly longer screws with small washers. That that the screws are tight on top with a washer. Anybody who can use this let me know.
2 bronco 11s
66
kentucky
ford bronco 11
I could use it . In the process of converting a 90 to 4.0 five speed . You take Pay Pal ? Zip is 42343 Thanks
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
in case you were wondering....
you are awesome.
mtnrgr
758
California
31x10.50
I opened another PayPal for this. I will get a shipping cost for you this week.
mtnrgr
758
California
31x10.50
2 bronco 11s
66
kentucky
ford bronco 11
