88' Bronco II 2.9L V6
Bionic711
Yes, fixed the relay, according to the wiring you gave me.
Junk Collector
Truck of Month
4,860
Rapid City SD
The pickup module is in the distributor
BlackBII
Ranger Custom
Truck of Month
984
UT
Yeah its inside the Dizzy. You need to pull the Dizzy to change it.
I had this very same issue, I replaced everything and turned out to be a short in the harness, between the TFI and the plug on the passenger side valve cover.
You can have all good components, but if you have a short in the harness, you're dead in the water.
