88 bronco limited slip diff
rochhound
arizona
i have 88 bronco II with 7.5 limited slip differential i need to replace the clutch
packs in differential! can someone direct to the best place to buy.
also what gear oil is best?
thanks
Junk Collector
Truck of Month
4,870
Rapid City SD
I'm not aware of anywhere other than Ford (maybe Randy's Ring & Pinion?)
Generic 80w-90 gear oil will be OK, not using friction modifier will make the limited slip work better too.
4.0B2
151
Walls, MS
4.0 v6
yeah ford is the easiest place to get those.. if they still even offer them.
