9" yoke/flange problem
hockeyryan
Vancouver, BC
4L
Hey so Im having problems finding a yoke for my 31 spline 9"axle. So my question is am i idiot and giving ppl the wrong info about the axle or are they hard to find? When i look on bronco graveyard all i see if 28 spline yokes. Is there something else i can run while being able to keep my stock ranger driveshaft. A local guy with a built ranger said hes running a 98+ flange and a 1 piece drive shaft.
Thanks
Maverick
FoMoCo MoFo
17
Eureka, California
All ford 9" gear sets have a 28 spline pinion unless you buy a special gear set with a 35 spline pinion (typically used for racing) regardless of axle spline count. So no, you are not getting the wrong info.
Mbxmitch
Does a stock 9 inch yoke flange bold to a 98 and up ranger shaft? Sure like to know
UrbanRedneckKid
17
Cass Co, Missouri
The oem yoke on my 78 Bronco 9", fit the oem u-joint on my 94 shaft.
Dunno if that helps, but that's all I got...
Sent from my HTCONE using Tapatalk 2
