93/94 rangers vs 95 and up
Shrek666
V6 4.0
Hey I just joined this site and after poking around for awhile I keep noticing that the 93 and 94 rangers keep getting grouped with 95, 96, 97. This is a major problem. In 93 ford redesign the ranger in all models and then in 95 changed everything again. Some of you might know this but when you try buy parts most of the stuff for a 95 wont fit on a 94
v8nick
302
What won't fit? When I bought my truck it was wrecked, it hit a deer at 60 mph. Mine is a 93, I bought a 97 without a motor or tranny, and I swapped everything over. I even upgraded the brakes from the single piston, slider calipers to the twin piston bolt on set up. The dashes are different as well as the steering shafts, but everything is interchangeable.
93greenbomb
sunny buckhannon west virginia
just because a parts store says its a different part number doesn't mean it wont work, or is even any different at all. remember if it looks the same smells the same and bolts on the same guess what its the same!
BeefStew42791
Kingsley, PA
what changed in 93 was the body style. This affected wiring layouts, grill/lights/windows, etc. In 95 however there was a much heavier impact when the obd1 diagnostics system that was in 94 and before, changed to obd2. Then there was also the interior and all. But then in 98 when they had another 'overhaul' some things didn't even change then. Such as the bed, tailight mounting, etc. I could go on and list about 95% of these kinda things off the top of my head but I have niether the time nor the energy. Have a look around this site for a couple months, that and actually tearing parts off trucks are pretty much the only ways to know if something will/might with a little persuasion/won't fit on other model years.
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
welcome to TRS Shrek666, i consider 93-94 to be their own little group because they are different, but they are still GEN III trucks, so thats why theyre listed with 95,96,97 (gen III 93-97, despite the differences in OBDI and OBDII).
Ranger44
23
Illinois
FORD
4.0 OHV
What changed between 93' and 94' on the body? The grill? Maybe?
Engine wise, a few things like EGR were added, mostly emissions. Some Manifolds were changed, and the fuel system lines on the 3L. A change from R-12 to R134A refrigerant? Not much there.
The main differences between a 93-94' and 95'-97' Gen III's are:
1). a switch from EEC-IV to EEC-V(witch called for different wiring routing, placement and design of things like the overflow tank, etc, and emissions equipment)
2).the dash/trim/door cards, and HVAC systems(so the bulkhead of the cap is "slightly" different)
3).grill
4).wheels(style)
5).the front beams got reinforced with more welds and more material at the lower ball joint
6). better dual piston caliper front brakes
7). exhaust changed a little (flanges between the y-pipe and cat) & some manifolds were revised.
8). I think they revised the carrier bearing design a little(but that may have happened halfway through 94')
9). the master cylinders are different(but can be swapped between)
10). the cruise control setup is different
11). they changed how the clutch master was mounted (actually on the bracket, and not through the firewall)
12). ignition systems where upgraded from TFI to EDIS on the 3L, and from DIS to EDIS on the 2.3's
13). power options were alot more common
14). and ABS and airbags became standard
15). auto transmissions became computer controlled
16) Speedometer read off a sensor at the t-case rather than a cable.
17) They changed how the radiator was mounted.
18). Core support may be a bit different.......
19). Overflow Tank
20). Air Intake, and filter
21). Plastic Intake and combustion chamber design on the 4L
22). Heads reworked on the 2.3(intake too)
23). Batch fire to actual SFI. (which led to the crappy CMPS on the 3L)
24). How the wiper blades attach are slightly different, so is the motor that powers them.
25). ?Fuel pumps?, fuel lines/fuel rails(returnless), injectors changed, EVAP system.
Did I miss anything????
