93-97 7.5RG Differential brake backing plates swap
sparky1222
I have a '96 2RWD 7.5 RG 10"Brake Differential that needs to be replaced (Pinion Bearing welded - can't remove.)
There appears to be a lot more 7.5 Differentials with 9" brakes than 10".
My question is:
Are the (7.5 RG Diffs,) 9" and 10" Brake backing plates interchangeable?
(Same Brake mounting holes & bolts?)
My inclination (90%) is that they are but just want to be sure.
Thank you.
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
PRovided you get your 10" backing plates from another Ranger that DOES NOT have the larger diameter axle tubes associated with the 31-spline axles....
I always went looking foe 91-up Aerostars when I was after backing plates...
But any 1993-97 Ranger supercab should already have 10" rear brakes
sparky1222
Thank you
Thank you for the answer, my existing #84 Diff has good 10" backing plates but I won't be using them (although I'll be saving them) because I've already bought a "93 #84 Diff (only 54K miles.)
Again thank you & take care.
AllanD
TRS Technical Staff
134
1987... sorta
'93 4.0
When I was switching out an axle assembly with an "issue" with a spare I would usually
1) disconnect the drive-shaft
2)drop the back cover and drain the oil
3) Pull the spider gear shaft and remove the C-clips
4) pull the axle shafts
5)unbolt the brake backing-plates from the axle tubes
& and only then
6) disconnect the shocks and u-bolts to drop the axle housing
Doing it this way AVOIDS ENTIRELY the necessity to reassemble and bleed then adjust the rear brakes, as I usually leave the backing plates hanging by Bungee (Or bent coat hanger) from the frame rail.
Having the axle shafts out lightens the whole assembly....
AD
