93 f150 crate engine question.
gottaba5spd
Hey guys I've been helping my brother with replacing the 4.9 straight 6 in his f150. Primed the oil pump, had pressure, then when we fired it up had no pressure registering on the mechanical gauge we had wired up. We called the number for Spartan and their tech had no idea, called a few friends and they were stumped too.
Anybody know what could be going on? It's a brand new spartan reman 4.9, no idea why it would be doing this.
Thanks in advance.
Sent from my SM-J320P using Tapatalk
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Is the 4.9 oil pump driven by a hex rod from the distributor? Is the distributor hex hole the right size? A mechanical gauge wouldn't be wired up, it would have a tube going from sender to gauge. Is yours mechanical or electric? If electric check for signal at sender. If signal there then suspect gauge.
gottaba5spd
Yes it's hex rod, it's the right size and it's a mechanical gauge.
85_Ranger4x4
17,905
SW Iowa
You didn't just wire up the light in the gauge?
No idea on 300 but on a SBF the rod is only held up by a clip, if you are not careful inserting the dizzy (or assembling or priming) you can push the rod down on the clip so it won't go into the dizzy shaft.
gottaba5spd
How would this be fixed?
gottaba5spd
Problem fixed. Turned out to be a bad oil pump.
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Thanks for the update.
Sent from my XT1032 using Tapatalk
