BeefStew42791
- Aug 4, 2008
- 2
- Age
- 33
- Kingsley, PA
- Ford
- Engine Size
- 4.0
Ok, to begin with, my 4wd hasn't worked from the getgo. I think either one or both of my hubs are junk because even when I jack the truck up, lock them in, and spin the front driveshaft niether front wheel will turn.
However, recently I had both of my front wheels & hubs off the truck when I was changing the front flexible brake lines. I noticed while the wheels were off, that the axle splines that make contact with the locked in hub have different lengths. On my driver's side shaft, it appears that the entire splined part of the shaft (about 2 inches) is visible past the outer locking axle washer. On my passenger's side shaft though, only about half an inch of the splined part of the shaft shows past the outer locking axle washer.
I can get pictures if they're absolutely necessary, but I'm relatively new to the technical details of 4wd systems and I've never torn into this particular part of the truck before. So I was wondering (and hoping) that somebody could tell me whether this is normal or if there's something screwed up in the guts of the ttb.
thankya muchly!
thankya muchly!
