93 ranger running poorly
1993rangerxl
Florida
4 banger 2.3L
This started a few days ago, started running bad after stalling it. Low rpm's runs like out of time, exhaust smells awful (not rotten eggs smell), heavy oil smoke, heavy carbon inside tailpipe. Over 3000 rpm runs pretty good but still off in power. Timing seams to be OK. Drove it home from work yesterday, started out same way part way home ran normal then few blocks away ran like crap again. Could use any help with this.
93 four banger, 5spd. 333k miles.
93 4x4
florida
Check your computer board on the driver side of the firewall take the board out and see you see any black dots under the diodes they leak on the board an can give you that sort of instant problem happened to mine and we have
The same year truck
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
I don't know particulars. I would be checking, the 2 wire temp sensor, the fuel pressure regulator, and the ignition spark. Any codes being thrown?
5.0L
I'd start with cleaning the MAF sensor. the O2 sensor could cause a lot of problems, but usually you get a CEL for it.
1993rangerxl
Florida
4 banger 2.3L
Ok, here goes a key on engine off codes.
111 (sent twice), 117,217,333,233,417.
Will run complete test tomorrow and see what happens.
5.0L
I read that a sign of possibly a bad ECM, or PCM is giving fake codes, or codes that don't exist. are you using a scanner or counting the flashes?
111 says system pass,
117: ECT sensor is/was low or grounded - ECT or haynes manual says temperature circuit below minimum voltage/indicates above 245 degrees
217: not in the haynes manual, but online chart says (M) Primary circuit failure - ignition coil 3 - Ignition Systems
333: not found
233: not found
417: not found
i'd look at the pcm. i just did mine on my 94 it was pretty easy to do. first i'd take out the old one, take the cover off and see if it is corroded inside or has any leaking capacitors. I got mine from rock auto, it was 120 bucks. make sure you get the one for your truck, as in 4 cyl, standard trans etc.
1993rangerxl
Florida
4 banger 2.3L
I'll be doing the more complete test today. I'm using a Sunpro code scanner. I've owned the truck 17 yrs and up to the last year lived on a limestone dirt road. The dust is still caked in every little nook and cranny there is. Very difficult just getting cover off test port. I'll post later what the scanner gives me.
1993rangerxl
Florida
4 banger 2.3L
Here are the codes I have so far. 111 which I know is no problem found, then have 172,173,332,334. Not able to do engine running test yet, has been running so bad it ran out of gas. Gas gauge does not work properly. Hasn't for years.
1993rangerxl
Florida
4 banger 2.3L
Played around with some of the connection underhood, put about a quart of gas in it(all I had here) started and seams to run better, need to get more gas first.
5.0L
Looks like you may have an egr problem.
1993rangerxl
Florida
4 banger 2.3L
Unplugged and plugged back TPS and IAC, also swapped relays for EEC and fuel pump. Running fine now!
