wr250rdr
- Apr 18, 2010
- 2
- Las Vegas
- ford
- Engine Size
- 2.3
Does anything other then the idle adjustment screw control the idle on these motors? I'll set my idle at approximately 950 (warm) and it will try to idle around 650 cold. I have done all the basics I don't have a vacuum leak that I can see or find with the ether test. But I'm not 100% sure that it's all routed right. If someone could chime in on what all gets vacuum I could eliminate this as a possible cause. The connections I am unsure about are on the passenger side of the bay. Also I do not get a code at all.
Thanks for all the help guys
