94 Explorer 4 X 4 rear ends into 88 B11 ?
2 bronco 11s
66
kentucky
ford bronco 11
Can get the complete front , I beams and everything attached. Pitman arm and tie rods etc . .. complete rear end both driveshafts . Is this a direct bolt in . I realize there’s some drive shaft mods . Thank you
Junk Collector
Truck of Month
4,806
Rapid City SD
Front is a direct bolt in, you need the steering linkage with it. Driveshaft will need to be shorter.
Rear is a different story, you will need to cut the leaf spring perches off and put them on the top of the axle, add shock mounts, and you may need different U bolts and plates. Your current driveshaft should work but you'll need to drill & tap holes for it in the axle flange as the bolt pattern will not be the same - easy fix.
2 bronco 11s
66
kentucky
ford bronco 11
Thank you. Is there a rear end housing with the bigger gears that’s a direct bolt in ? Thanks in advance
Junk Collector
Truck of Month
4,806
Rapid City SD
Ranger 8.8 is close... not much of an upgrade though.
FYI, the leaf spring perches on a B2 are spread apart at a different length than they are on a Ranger axle. IIRC they are wider by something like an inch or two. Ran into that with a B2 axle that someone swapped into a Ranger that I ended up with, it did not fit very well. So really, the ONLY truly "bolt in" axle for a Bronco II is one that originally came out of a Bronco II, and those would all be 7.5s.
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
Direct bolt in? no, bronco II's have different leaf spring pad placement than Rangers, depending on your use a 7.5" can handle some abuse, I think the explorer 8.8 is the closest to bolt in you'll get...
