94 Ranger Power Steering/Manual Steering Gear Box Interchange
wcurtin1962
Columbus OH
2300
Are there any differences in interchange between a power steering, manual steering gear boxes for 2WD 92-94 Rangers?
alwaysFlOoReD
5,132
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I dont know for sure but manual most likely has different gear ratio. So more turns of the manual steering wheel to get the same turning circle as power
SenorNoob
589
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I've heard that. Even seen the difference posted somewhere. Can't seem to find any info except for early Mustang stuff now.
codylink
4
Canada
Mazda
I'm also interested in this. If I have to replace the steering box I might as well delete that pump which is nearing end of life.
Anyone running a manual box can give their opinion on how much of a pain it is? I had manual steering on my Honda years ago, but this could be different
racsan
4,497
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
pitman arm is different between a power steering & non power box. The manual steering pitman arm is almost impossible to find.
Other than that I believe its a simple swap.
BlackBII
Ranger Custom
Truck of Month
983
UT
The pitman arms are indeed different - the manual box has a smaller sector shaft diameter. And, the input splines are different as well so the steering shaft will need to be swapped/customized. If you're running skinny tires it's not a big deal, it's easy enough to turn, but it's more turns lock to lock. The boxes themselves have the same bolt pattern, so they'll bolt into place.
codylink
4
Canada
Mazda
Alright, that makes my decision for me. Many thanks
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
You can go Volvo electric pump as well. Have one on my 1988. I like it.
Hooks right up to factory box plumbing with adapter hoses.
