- Aug 15, 2007
- 0
- Avon, IN
- ford
- Engine Size
- 4.0l V6
Hello TRS, glad to be back after a few turns on the roller coaster we call life. I have recently gotten back to being an observer and after much research, I cannot find the answer to my particular question. Please help me if you can.
I have a 94 ranger that was originally a 2wd with the A4LD automatic. I eventually converted to manual with the M5OD-R1 and naively picked up and installed a mechanical BW1350 TCase with the slip yoke. Now when I go to get a front shaft made I'm told with my lift, it can't be made and I need a front yoke. Never even thought about it.
I'm currently looking for a mechanical 1354 and noticed with manual trucks, the speedometer cable location for my year is located on the t-case. So will a BW1354 from a 02-03 Level 2 be able to work with my stock speedometer cable location? Or how would that work? I know the speedometer cable VSS went out in 95 I believe. I would rather keep the stock cluster so I just need to know If I find one will it work or and I stuck to 90-95 ranger and 91-95 explorers.
Thanks so much for you time.
