95 5.0 expo-ranger build thread
5ohRanger
Well crap lol. How so?
5ohRanger
Well....I had to backtrack :( The X wiring harness had a couple items in the wrong spot and I didn't want to botch my inner fender up to hide/make room for those items so I reinstalled the ranger wiring harness.... Inside and out. So I swapped the dash back and swapped out the dash pad with the X dash.
I got a new relocater in the mail yesterday and got that installed so now I'm waiting for my headers to arrive so I can get the show on the road! (No pun intended)
I went ahead and bit the bullet and bought a new radiator last night since that was gonna be the main thing holding me up for this Saturday.
Thought I'd add a little authenticity to my build since I don't plan on selling this truck and my original cluster bit the dust.
5ohRanger
I fired up the engine tonight! Installed my radiator and ran all the trans lines.
Got in my Headman 89500's........ Should of read about these headers. You would think they would work great seeing how they are made for this swap???? But as I found out and just now read, the passenger side dumps straight into the I beam suspension. I'm in a pinch to get this truck done so I don't know whether to use them or make them take them back and order a set of 88400's??? Would the frame need notched for a set of 88400's?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
I couldn't remember if it was the frame, firewall, or the beam the 89's faced, guess you found it. The 88400's are supposed to clear everything better than the 89500...
SVT
5ohRanger
My 88400's are on their way... Wow I'm 3 sets of headers into this!!!
5ohRanger
What kind of upper/lower radiator hose do I use SVT? Looks tight around that alternator! I'm using the 4.0 2 core radiator.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
I can't remember if I used the stock 4.0, or the stock 5.0 for the upper, the lower I used stock 87-93 mustang V8 lower trimmed on both ends (its in the thread, first post). I think a stock V8 explorer lower would work (99-01 without the oil cooler)...
SVT
5ohRanger
Update! I got my power steering all hooked up today! Bought a tubing bender tonight to redo the trans lines going into the radiator since the top one is hitting my ac pump.
Got the Headman 88400's in the mail today! I called summit and they are going to let me return the 89500's thankfully even though I did install them.
Picked up my driveshaft today also.
I was looking at the water pump and I think I'm gonna take a cut off wheel and cut the threaded part off the end to give me almost an inch more clearance since I gotta run an electric fan anyway. Hopefully I'll bee and to drive it this Saturday! Then the body work will be done after that.... So he says *facepalm*
Stangman92
NW Chicago
Glad to hear your getting close, Get us some more pics!
5ohRanger
The 88400's worked!!! Finally!!! After 3 different sets of headers!!! I did have to notch the passenger side frame real a bit but I just DID NOT want to use those horrible exhaust manifolds that came with the X.
Before
After
I also gained some clearance for my electric fan by cutting the threads off my water pump.
So since my header worked I was able to put everything back under the hood. I pretty much got everything back together. I got to top off the trans fluid and oil. Oil pan with the relocater holds 6 quarts of oil! Got my brakes all hooked up just gotta bleed those. Also picked up the 99 5.0 Explorer radiator hose for the bottom.
One thing I got to do is bypass that clutch safety switch so my engine will start using the key! I swapped relays and everything until it final dawned on me! This was a manual shift truck! It has a clutch switch! I'd like to jumper it for the time being until I can go to the junkyard and pull the bypass switch from an automatic.
Picked up a 1400cfm 16" electric fan from the Zone tonight so I'll get that installed tomorrow!
Tomorrow!!! She should be rolling the tires over!! Here she is in her present state!
5ohRanger
I got to lay down my first black mark today! It will do it with no sweat whatsoever! I took it easy cause my bed isn't bolted down and I didn't want it to slide into my tires and damage it or even worse lose it on the highway! https://youtu.be/sd_AvtGjsBQ
My 16" electric fan was too deep and wouldn't work so I took it back and got a 12" and a 10" fan and it couldn't have worked out any better! Also picked up an adjustable temp switch 2 fan controller that works with the ac to cool the condenser when the ac is on.
5ohRanger
I have a couple issues that do need addressed.
One is my alt is not charging. My wiring harnesses is plugged in and all the fuses for the alt (under hood/inside cab) are good. The green with red stripe wire isn't getting any power and I'm pretty sure that wire needs 12v to make the alt charge. So not sure what to search for now???? Prob doesn't matter but I did jumper the clutch safety start switch to get it to start of the key. I only jumpered the pink/pink white???? wire and left the safety switch unplugged so?????
Another thing that bugs me is the speedo isn't working. I was under the assumption the speedo was not an issue whatsoever with this swap???? Any tips there??
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
The charge excite wire should be in the 12 pin connector next to the abs module. The speedo, is your vss located in the tailhousing/tcase? Are the wires from the vss going to the ecu?
SVT
5ohRanger
I found that excite wire in the 12 pin connector and checked it to find no voltage. I did read last night that if the charge light blows in the cluster then it won't charge..... Funny thing is I ran this cluster in the X for a couple days before I did the swap and it charged fine. Maybe Monday I'll pull the cluster out and check the battery light.
Only plug I recall on the trans was one large plug (other than O2 connectors) and it is connected. I need to take it for a spin really. I did the burnout and parked it yesterday then moved it around last night I'm pretty sure I drove the thing 1/10th of a mile but possibly not? I was moving it last night and looked down and the speedo wasn't moving but I possibly wasn't going fast enough??? So it possibly could be working.????
