'96 2WD: 14"->15" upsize... anything wrong with this?
fireant
Central TX
Howdy folks.
i've got my hands on a gem of a Ranger.... 96 4.0 2WD auto with low miles.
The wheels on it are the stock 14x6 4-hole design, and I measured 3.75" backspacing on the one that had a blowout (the tires are shot!)
So this is a perfect opportunity to upgrade the wheels and tires. I'm looking at summit racing's deal on Cragar Soft 8's in 15x8 with 4" backspacing ( http://www.summitracing.com/parts/CRR-3975812/ ) , plus some 235x75/15 tires.
In a nutshell its this:
Wheels:
14x6 +3.75" ---> 15x8 +4"
Tires:
26.7" height ---> 28.9" height
Would there be any problems with this setup?
3,614
It'll work.
fireant
Central TX
Thanks. I'm assuming they will stick out a little more than stock, but not be a problem, correct?
3,614
As long as you get ones with a 4.5X5 bolt pattern they will be fine. Speedometer might be a hair off, nothing awful.
Rose2300
7
ID
Toyota
3.4
Howdy folks.
there's your problem, rangers have a 5 hole design. the pic shows this too. i'm probably just trollin cuz i hope you made a typo :icon_thumby:
Thed
19
Raleigh, NC
They work.
fireant
Central TX
By 4-hole, I really meant 4-spoke (the wheel design, not the bolt pattern).
Anyways, I went with 15x8 Soft-8s and 235/70/15s and they look great. Thanks for the help.
