- Dec 20, 2010
- 7
- Ford
Hello everybody!
In a couple of weeks im installing the oem fog lights to my 96! Yes! I found a set of oem brackets, thanks to edwards1687
Ive found several wiring diagrams for the Rangers, but none is 100% complete or is unclear.
So, for any electrical guru out there... is my plan ok?
The idea is:
RELAY:
From 86 to pin #3 on the fog light switch (Lt blue/Black)
From 87 to both fog lights and pin #6 on switch (tan/orange)
From 30 to +12 battery (fused)
From 85 to pin #5 on switch and also, to the parking lights circuit (red/black)
On switch pin #4 directly to ground (black)
Question 1: is this plan ok? Any modification, sugestion and/or corrections?
Question 2: where do you recommend to hook up the red/black wire on the parking lights? (lights switch, fuse box?)
I want to run my fog lights with the parking lights and low lights. I also want the icon on the swith to light up when the park lights are on, and also, i want the green led to light up then the fog lights are on.
Hope Ive explained myself correctly...
Any input will be appreciated!!!!!
The idea is:
RELAY:
