96 Ranger I beams install question
TOPDOG2007
August 2010 STOTM
6
Ga
I have a set of Djm I beams(3") and I have already installed an Explorer rear end(which was flipped from the factory and the rear sits about 3" lower). Can I stick with the factory springs? Or will it make the truck sit up the same? I am not looking to scrub the ground because I have a 5.0 installed and I am going for the "sport" look.
rat_ranger
December 2009 STOTM Winner
MTOTM Winner
moving with the army
2.3 duratec
The dream beams will give you a 3in drop with the factory springs. Thats what they are designed for. It should balance out your rear drop well.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Because you have the 5.0L it might sit a little lower than 3"...Yeah the extra weight will have no effect on the beams, but it will make the factory springs compress a little more, if you haven't compensated for it already. I run the dream beams as well as dropped springs, so I'm sitting pretty low, well, real low as I have modified springs, but you will like the outcome and those dream beams are strong as hell despite what some may say:icon_thumby:
SVT
TOPDOG2007
August 2010 STOTM
6
Ga
Ok so I installed the Dream beams today..and its sitting perfect now. I will post a picture tomorrow...it was dark when I finished.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Dont forget to bring it by the alignment shop:icon_thumby: Make sure you go to a shop that is very knowledgeable with Ford suspensions, cause I had a shop screw mine up worse than what is was when it first went there, and I did a better job in their parking lot just eyeballing it, and they still charged me$60!! Never going there again!
SVT
slammedxonair
Vermilion, OH
91 and 00
yea the toe will be off the most with the drop beams.
TOPDOG2007
August 2010 STOTM
6
Ga
Yep the tow is clearly off..its okay for now though..I still have about another month worth of work before I get the truck running. I am probably going to have a hard time finding someone to line it up..I live in North Ga. I may have to haul it down towards the Atl to find someone.
slammedxonair
Vermilion, OH
91 and 00
Any alignment shop tech with a brain should be able to align it on a rack.
TOPDOG2007
August 2010 STOTM
6
Ga
Question...If I flip my shackles will the rear sit lower than the front? Or will it let the truck sit even?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
If you flip the shackles it'll give you roughly 3 inches of drop, this combined with a spring under conversion you should do a C-notch, may have to do a notch, your real close to that point
SVT
83bagged
January 2010 STOTM Winner
MTOTM Winner
LOUISIANA
302
post pics of V8! lol
multiranger
Praise the Lowerd!
MTOTM Winner
17
Loganville GA
Sweet ride bud!
No members online now.
