97 2.3 AC blowing hot air
3ncrypt3d
Indiana, US
2.3
I have a 97 2.3 2wd model. I just replaced a lot of the AC components, since they were either old or leaking. I properly vacuumed and then charged the AC lines. I added 1lb 5oz of Freon, and 3oz of a Freon/oil mix. To me, it feels like the heater blend door is going bad. The actuator does work, I pulled it out and confirmed that. Is there an easy way to pull out the actual blend door itself and see if it’s stuck? I’m not pulling my dash, but I’m not opposed to cutting parts of the underside. Any help, or maybe something I’m missing, would be appreciated!
Edit: Should’ve clarified. I can hear my compressor engaging, for about 35 seconds, and then disengaging. My last ranger did the same thing, so I’m assuming that’s normal.
8,374
Are the AC lines by the heater box getting COLD, and the AC box itself where evaporator is should be getting cold with AC on
Images here of heater box and where evaporator is: https://ww2-secure.justanswer.com/uploads/lostrider/2010-06-19_134714_1.gif
With AC on there should be some cycling but not alot, could be one of the pressure switches is cutting off compressor, but 30second on should be enough to feel COLD lines
Yes, you can fold down glove box and cut a hole to manually move the blend door or "see it move" with actuator control
Google: Ford ranger blend door fix images
There are pictures on where to cut.
The actuator may be working but the slot in the blend door is broken
Info here: https://www.therangerstation.com/Magazine/Summer2009/blend-door.htm
3ncrypt3d
Indiana, US
2.3
Yeah, they’re ice cold. Which I’m assuming is good? I’m gonna go ahead and just cut into there and see if it’s the blend door.
