sfwjesse
- May 9, 2008
- 1
- Age
- 41
- New Hampshire
- Ford
- Engine Size
- 4.0
My dad got a 97 ranger with 127k on it, 5 spd, 4 cyl, 2wd, for 200 bucks. The guy said his mechanic said the throwout bearing was junk. My dad just pulled the tranny and I think it is junk. Maybe someone like AlanD could confirm this for me. Here are the clues:
1) Fluid in the bell housing, does not appear to be break fluid. The gasket for the cover the end shaft comes out of is leaking. When he drained the tranny, only about 1 qt. of fluid was in there.
2) Whining noise when clutch is engaged. Goes away when disengaged
3) a small clip that resembles the shape of the copper colored staples they use in cardboard boxes was stuck to the magnetic drain plug
4) The previous owner said one time it popped out of 4th gear while driving, and he had to hold it in to get home
5) The slave cylinder plastic was somewhat melted to the aluminum behind it
6) end shaft has about 1/16" inch of play (not good but dont they all?)
So, my theory is it ran out of fluid and is burnt up. I think whatever got damaged is beyond the skills of a couple backyard mechanics, so i am now looking for a used one. Am i correct in assuming this thing is junk?
