97 to 93 dual piston brake upgrade.. new master cylinder?
JimRummy
Los Angeles, CA
245 CID 4.0 V6
I'm doing the 97 dual piston new knuckle/rotor upgrade, for my 93 4.0 2wd, and I was probably going to replace the POS Duralast master cylinder with a motor craft one. My question is should I stick with a 93 master cylinder, or change it to the 97 master cylinder so it matches all the other components... The 97 is actually $10 cheaper too. What do you guys think?
17,855
SW Iowa
If it works ok I would try and see how it behaves with your '93 MC.
That is my plan for putting a '95 D35 in my '85 anyway :dunno:
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
get on one of the parts sites and check the bore diameter of the 2 master cylinders. if they are the same you should be good to go.
JimRummy
Los Angeles, CA
245 CID 4.0 V6
But do you actually think the newer 97 would be advantageous over a 93?
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
I switched to the two piston brakes at the same time I converted from a 2.9 to a 4.0 AND from 2wd to 4x4...
I believe the master cylinder I'm using is from a 1990
(It WAS 7 years ago... )
JimRummy
Los Angeles, CA
245 CID 4.0 V6
Alright, well guess the 93 it is. I was only asking because there are some updated sensors (cruise control I think) for newer master cylinders, and the newer one (97) is cheaper.
